where does it go?
where does the apex seal go? i don't even know where to put it. help me out. thanks
Did you get the atkins rebuild video?
Re: where does it go?
It looked pretty serious. CALL THE ROTA-POLICE!
well the Apex seals go on your engine rotor. you need 6 seals for 2 rotors
3 seals on each rotor. the atkins video is good and so is a haynes manual. both of them tell you how to work on your car well i hope i was some help |
Yeah...contact Atkins and say Black Rocket sent you ;)
dang i messed up again (ignore this)
look at each point on the rotor and you will see a slit and that is where the apex seal goes and the spring goes under the apex seal so it pushes the seal against the housing acting similar to the rings on a piston
http://www.mazdatrix.com/8pics/8engine/rotor2.jpg |
I woulda deleted this thread from the very first post.
