LSD?
do 3g's come stock with limited slip diff? ive been lookin but i cant find shit. thanks
FDs and FCs both come with LSD.
Though, not all models :(
im picking up my fd next week. is their anything i shoiuld do as soon as i get it. and what should i look for when examining the car to se if its not a POS(other then the same shit as any other car)
im not farmiliar with horespower to 1/4 mile time ratios, but the car i am about to buy i have a dyno sheet that says 289 HP/ 236 trq. my friend is telling me that it will be capable of 12 second passes. but im guessing low 13's. someone enlighten me
1, change all the fluids (very important) including tranny 2, ck the fluids to see if anything needs to be ck'd out (excessive metal flakes in gear oil/trans fluid) engine oil the same way except for possible water contamination (hope not) 3, ck for brake to see how it performs (normal) 4, If all cks out...SEE HOW FAST IT GOES :twisted: |
If not familiar with timing...you'll be SOL. If you're familiar I bet you'll be running low 13s with that number. |
thanks pall
