BMW E36 for trade(KY)
Really looking to trade for an fc. Looking for a fairly clean one with little to no problems, just cosmetic if anything. Must run and drive as it will be my daily.
All trims will be considered. So just send me an offer. Contact Info Name:Brandon Number:502-645-3328 Loaction:Louisville,KY Here's some info and pictures. Trade value $5000 Just installed Tein S-Tech lowering springs. Pic with new springs http://img689.imageshack.us/img689/7803/skylineh.jpg Uploaded with ImageShack.us http://img577.imageshack.us/img577/3...d64afb6dab.jpg Uploaded with ImageShack.us 1997 328is 171,XXX car will last alottttt longer. -Has new brake pads -AC/Heat works great -Engine is stock M52 with Cold air intake -Has had head and valve cover gaskets replaced -Coil pack replaced -New plugs -Dual tip cat back exhaust sounds deep and mean, not too loud too loud not too quiet -Transmission is 5 spd Stock Suspension is stock and amazing, it sits low for a stock car and rides immaculately. You don't feel a thing and it corners well. -Wheels-Style 41 (streamlines) in good shape -Have all four center caps new from bmw -Car has oem carbon fiber m3 spoiler A very rare sporty spoiler. -Interior has 2 stage HEATED leather creamish white interior -Does have minor wear on drivers seat and center arm rest Lighting- all from bavarian auto parts -50/50 oem style red clear tails---Gave stock to a guy in need -Clear oem style corners----------Have stock ambers -Clear oem style side markers----Have stock ambers -Block off panels for fogs -Bad Drivers seat wear Also crack in the front bumber Headliner sags dent in nose panel but I have a new nose panel and grill to go with it. Minor dings Car has two CEL's on One is check control. I recently got the tail lights and when I ordered the bulbs one was slightly bent at the end so I haven't got around to putting a new one in but that's for that code. I will replace the bulb before trading and magically make that cel go away. The other is check engine light Car has no catalytic convertor So that's for that code. |
