add coolent buzzer !!!
my add coolent buzzer will not stop buzzing. my coolent is fine the buzzer must just be broken or somthing.so were is the buzzer located so I can take it out and smash it with a hammer.
The sensor may be bad or could be a bad wire. I assuming you have checked your coolant levels, have you tried bleeding the system to make sure there is no air in there?
I will try bleeding it
bleeding it didnt work
What about the sensor, it could be bad.
is the coolent level senser the one on top of the radeater?
