-   -   removing emission problem (http://www.rx7forums.com/forum/showthread.php?t=2385)
Duneratz00 08-04-2011 01:10 AM
i have removed all the emission no more vac hoses or air pump car has good cumpression the problem it will not start it will turn over the injector work but the car is flooding like mad someone told me that the timimg needs set different they said that because the emission is removed the car uses less air and the fuel is much high now in the mix so if you now any forums or even better a video that shows this emission removal in work
LunchboxCritter 09-03-2011 03:25 PM
Which series (s4-s5)? Turbo or NA? What all did you remove? Why did you remove it? Was your car starting, running, and idling properly prior to removal?
It sounds to me like you have a vacuum leak. Emissions removal should not cause your car to not start. You should still have some vacuum lines, I believe 5 is the fewest you can run, depending on make/model.
mikes88GTU 03-14-2013 08:23 AM
5th and 6th port need around 2 or 3 psi to work properly. It was getting the power from your cat but thats only if its a 6 port na 87 or 88. Possibly a few more 13b models fall under the particular criteria.
