-   -   runs with a miss when u first start it and then dies after about 1 minute (http://www.rx7forums.com/forum/showthread.php?t=2321)
josh 05-04-2011 07:56 PM
I have a 1979 rx7 and some times it will start and run real good for 5 to 10 minutes before it starts running with a miss and dies and other times it will run for a 1 minute missing the whole time before it just dies but if it starts to die and you start pumping the hell out of the gas in time you can keep it running it just misses like crazy any kind of an answer would be nice I'm going to take the carb of and have it rebuild for starters and go from there, but im not sure that is it it sound like its some thing in the firing system I thank but don't know I'm a mechanic by trade but this is the first import I've owned or worked on so I'm kind of lost for the moment.
BoostedFC 05-04-2011 10:29 PM
Air, Fuel & Spark just like any vehicle. As I see you say you are a mechanic start with the basics. Clogged filters, check your plugs, vacuum leaks, check your Dizzy & wires.
josh 05-08-2011 09:21 PM
well the car has been setting for about 5 years so im sure the carb need rebuilt
BoostedFC 05-08-2011 11:06 PM
You did use new gas right & drain the old gas?
