New to Rx-7's and need some help
I own an 87'
problem is when i accelerate the car dies. we replaced the mass air flow censor and it wont stay open for some reason so we have it where it stays open at all times. but once the car gets to 2500 RPM it cuts out and dies... any suggestions? |
Does it idel good?
Yeah the car idols fine.
we are buying a new fuel rail and thinking of rebuilding the motor but i hope it doesnt come to that. |
i just got a second gen today but about the windows dose the nain power go to the passenger window???
The connection goes to fuse box @ driver side. |
lol. on the sec gen head lights how do you ajust them ?? one of them is up just a little bit??
also i dont have the passenger window switch but i do have the driver side so can i get them down???
As to headlight adjustment, pop the headlights up and adjust screws located at the bottom center and inner side. If it does not maintain tension ck the tension spring.
Yeah, if you have a driverside window control, you should be able to regulate pass window. |
