Car won't idle
I recently just got my motor rebuilt, and new power fc, the car will not idle but runs fine when its moving, i know its not compression because i have 2mm seals and i dont notice any power loss at all please help
I'd ck for vac lines.
does anyone think it could be my alternator??
Simple alt troubleshooting; in the evening rev your engine and see if your headlights dimms and brightens as you change RPM.
I have tried that alt test and yes all my lights dim alot
mine does same thing! but when i drive it spits and sputters and every now and then kicks it in the butt! its been sitting awhile though maybe carbon build up also?
Do you have under drive pullies on your car? Also you can make sure that all of your grounds are secure. FD3s have bad grounding issues. EB Turbo |
Have you done a compression test? Just because you used 2mm seals does not mean much.
