NY 1986 Rx7 Needs Rebuild $1200
Fc3s 96k on body, 10 k on body 5k on 13b non turbo, half bridge port, RB header and the rest is 3 in. stainless steel to a Manzo T-II straight through muffler, all emissions deleted, needs rebuild because the previous owner made his own block off plates used too much sealer and i believe it is being eaten. Also needs some wiring, paint is faded, front fenders are rotted underneath if perfect(yes I checked) and pinch welds are a little messed up from being jacked on. 5-speed Manual, short shifter, good clutch, has lsd, no rust or rot, solid car, lots of labor and time public in. $1200 firm located in Troy, NY.
For more info text me @ 5189445413 http://uploads.tapatalk-cdn.com/2016...d436cc38c9.jpghttp://uploads.tapatalk-cdn.com/2016...a107fd6c18.jpghttp://uploads.tapatalk-cdn.com/2016...e14a8f2e59.jpghttp://uploads.tapatalk-cdn.com/2016...228a87f179.jpghttps://vimeo.com/191519153 Sent from my SCH-I545 using Tapatalk |
