-   -   1988 rx7 o2 sensor wire location. Please help! (http://www.rx7forums.com/forum/showthread.php?t=16781)
Tarantula 10-23-2016 06:37 PM
Hello everyone, I purchased a 1988 RX7 Non-Turbo and it failed smog because O2 Sensor wire has been cutoff on wiring harness connector side. I cannot find the wire in the harness anywhere. I have looked at both sides of the engine harness and under the car but no luck.
I believe I have the correct wiring diagrams and it says the wire should be Green/Yellow Stripe but there is nothing loose, cut, or any connectors unplugged that have that color wire. The only wire I can find unconnected is on top of the engine by Throttle body and it is Green/Black Stripe.
Please help ASAP.
Thanks, Chuck
rotorlife 04-11-2017 12:51 PM
I was touched by the same problem, help with advice
