Jesse |
01-15-2016 02:05 AM |
Starting Issues(Will not crank)
Hey, I have an FD with some wiring issues due to some jackass previous owner. I am trying to get it to crank and all I can get is a click. I tried jumping the two fat wires on the start cut relay and it still does the same thing. Am I able to run the 1Q(clutch-switch) or 1R(neutral-switch) to ground or a resistor or something to override that part of the system? I am not positive that this is the issue, but I think that this is a good start at process of elimination in finding the culprit of my problem:confused:.
