Huge Parts Sale (RX7 FC, Cosmo JC, RX8, REPU)
Hey guys, I just joined this forum, basically to help out all the rotary enthusiasts with parts. I have a garage full or goodies. I sold all my rx7s so everything is up for sale. All my prices are negotiable. Prices do not include shipping, that's extra. Please use email to contact me, or if you want pictures. I will try to update this list weekly.
Email: [email protected] Location: Marysville, WA 98271 Payment: PayPal or local pick-up RX7 FC ---Interior: Door sills (Pair, Black) x2 $100 Door sills (Pair, Blue) x2 $60 Random interior plastic panels (both in black and blue) $10-$40 Blue glove box/compartment (complete) $40 Heater core $40 Blower motor $40 Door panels (black, pair, driver side speaker cover torn a little) $160 Glove box lid (black, has no latch) $20 A-Pillar (driver side, grey color, manual seat belt) $60 Gauge bezels/surround (w/ out or few knobs) x2 $80 Gauge bezels/surround (complete with knobs) x3 $160 Gauge clusters x4 $60 Map light assembly (gray) $20 Rear view mirror (black) x2 $20 Map light & mirror (complete, black) $40 10th Anniversary horn cover x2 $60 Radio sleeve $10 Gauge cluster lens (brand new) $80 Parking brake handle w/ plastic panel $20 Center console (black, manual seat belts) x2 $80 Glove box lid (black, complete) $20 Vent (dash/windshield, brand new, pair) $80 Radio sleeve & connector (Metra, complete, brand new, sealed) $20 Washer fluid reservoir $20 Door panel lights (pair) $30 Door handles (pair, interior, black) $30 Door handle sleeves (pair, gray/blue) $10 Rear hatch locks (pair) $40 ---Exterior: Rear bumper w/ foam insert (s4, white color) $60 Front bumper w/ smoked/tinted turn signals (s4, bumper white color, can sell turn signals separately) $60 Bumper support (front and rear) $40 each Headlight assembly (Pass. Side, white, no motor) $40 Sunroof rack $80 Side mirrors (pair, power, black) $100 Headlight cover (right, black) $20 Fender flare strips (bendable, complete set) $40 Front lip/chin guard (black, about 1”) $40 3rd brake light lens $20 Side lights (2 pairs, red) $30 pair 3 brake light (complete) $40 Horns (Knight, pair) $30 pair ---Engine, Transmission, Suspension, Mechanical: Transmission Turbo II 5 speed w/ speedo cable $400 Front and rear struts (everything is stock, besides 2 rear springs, which are Tein. Stock ride height and stock feel.) $100 Coolant reservoir (windshield) $20 Coolant reservoir/relay front Plastic Covers (that go in front of fan shroud) $30 pair Power steering pump x2 $40 Belt adjusting bracket $20 Belt adjusting bracket w/ power steering pump $50 Air pump w/ belt $40 Strut tower sensors (front, pair) $40 Air box (n.a., s5) $60 Battery tray (modified for behind seat bins) $60 Ignition coil packs (N326-18 100B trailing) $40 Steering pipe & fitting $10 ---Switches, Relays, Sensors, Modules: Mirror switch (black) $20 Power steering module $20 Suspension adjust module $60 ABS module $40 CPU x3 $30 Cruise control unit module $20 EGI main fuse block w/ fuses $40 ABS relay $20 Solenoid resistor $30 ABS speed sensors (complete set) $200 Relays (random, 3 total) $20 for all Door lock relay $10 Atmospheric pressure sensor $20 Pressure/boost sensor (N327) $80 ---Motors Headlight motor (driver side) $40 Turbo II starters x2 $100 Auto trans. Starter w/ TII guts $100 Auto trans. Starter w/ bigger solenoid and motor $80 Wiper motor (windshield) x2 $30 Wiper motor (rear hatch) $60 COSMO JC 20b ---Interior: Gauge consoles x3 $200 Center vent assembly w/ buttons x2 $60 Digital clock x2 $30 Steering column panels (beige) $30 Steering column/ignition vents (beige) $30 Vents (beige, dash → door, dash side, pair) $30 Eunos horn $20 Cassette player $60 Rear cover panel $30 Rear headrest (adjustable) $240 Panel strip (black) $20 ---Exterior, Lights: Turn signal (front left) x3 $30 Turn signal (front right) x3 $30 Headlight (left) x4 $60 Headlight (right) x4 $60 Rear tail lights (complete set, Eunos, right tail is scratches a little) $80 Middle Eunos tail light garnish (has scratch)$40 Hood props/shocks x5 $30 each Side view mirror (power, right side, damaged) $40 Mud flaps (pair) $60 Horn (Knight) x4 $20 Strut tower caps x4 $20 Front grills w/ ornaments x3 $40 ---Engine, Turbo, Brakes, Mechanical: Intercooler (looks new) $140 ABS/Master cylinder unit $200 Intake pipe w/ valves $60 Twin turbo chargers x2 $200 Downpipe? (OEM, w/o2 sensor) $60 Rubber intake pipe $20 Single turbos x2 $80 Radiator (Calsonic NF01, used but in good condition) $120 Fan clutch $60 A/C pump $60 Diff. (N8225, no housing) $80 Throttle body $120 Exhaust manifold x3 $160 Air pump $60 Intake y-pipe w/ valve (polished/galvanized) $100 Throttle body → elbow intake pipe (brand new) $100 Random intake pipe (polished/galvanized) $80 Random intake pipe w/ valve (polished/galvanized) $100 Random intake pipe w/ valve $60 Twin turbos w/ intake piping and valves $300 Coolant reservoir $40 Rear brake calipers w/ pistons x2 $30 Throttle body w/ sensor $160 Throttle body (rebuilt) $140 Water pump (brand new) x2 $140 Air box w/ carbon fiber insert $120 Upper intake manifold (brand new) $240 Cover panel (carbon fiber, engine bay?) $200 Brake pads w/ hardware (brand new, front and rear) $60 per set Steering pipe & fitting $20 Fuel pump (brand new, 20B, Denso 195130-0771, 250 lph@[email protected]) $360 ---Switches, Relays, Sensors, Modules: Steering column controls/switches x2 $140 Relay junction w/ relays $100 Electronic control system module x2 $80 Igniter module x2 $80 Resistor $40 Eunos H. L. Controller $80 Central processing unit CPU x3 $60 Gas door/hatch push button x3 $40 Trunk push button x3 $40 Defrost button x2 (one good, one damaged a little) $40 Dimmer switch x2 $40 Pressure/boost sensor (N327) $80 Flasher relay $30 Transmission speed sensor $80 ABS module $120 EGI modules x3 $160 Throttle position sensor $60 ---Motors: Window regulator assemblies w/ motors (brand new, left and right) $120 each Starter x2 $80 ---Other: Seal plate (brand new, plastic) $40 RX8 ---Pre-Order: Pre-order thermos & mug set (brand new, includes Road & Track rx8 magazine, brochure and a stand) $160 Stainless steel mug $20 Pre-order brochure, parts catalog, and magazine (JDM) $40 each RX8 Lanyard (brand new, red) $20 REPU ---Interior: Steering column cover (like new condition) $80 Horn cover (like new condition) $60 UNIVERSAL ---Performance: Razo shift knob (new in box, light weight, white color) $30 Front Sway Bar End Links MOOG K700538 (will fit s10, blazer, jimmy, bravada) $20 both Front & Rear Sway Bar Bushings (Energy Suspension 33 mm and 23 mm, GREASABLE) $30 both HKS 150 (cage and filter) $30 HKS 200 (cage and filter) $30 HKS 200 (filter only, brand new) x2 $20 HKS 150 (filter only, brand new) x2 $20 Simota high power air filter w/ carbon fiber heat shield $100 Turbo timer (M's Mk100) $100 HKS electronic valve controller (like new condition) $60 Metallic insulating tape (2,000 F) $20 B&M new volt coil power unit (like new) $140 ---Rotary: Zoom-Zoom metal license frame (brand new) $20 MAZDA decal/sticker (about 8” long, 1.5” wide) $20 Random rotary decals/stickers $10 each Rotor shaped oil cap (aluminum) $20 Thermostat o-ring (rubber, new) $5 3D rotary engine crystals x3 $40 Plastic seal (not sure for what) $5 Atkins oil filters (brand new) x2 $15 Mazda oil filters (brand new) x5 $20 Oxygen sensor (brand new, Borg Warner, 1 wire) $40 NGK spark plugs (leading, like new condition) x6 $5 each MazdaTrix t-shirt (new) $20 ---Other: Aftermarket steering wheel horn (JDM leaf) $10 Battery tray (universal) $10 High pressure hose (500 psi) $20 Blue carbon fiber plastic sheet (13”x32”) $20 DEI siren (new, never installed) $10 Escort Passport mirror mount kit (new) $10 Valentine-1 stealth box (black) x2 $20 Kenwood KCA-M112 ten disc magazine (brand new) $10 Automatic power antenna (universal) $20 Adhesive tint film $10 Adhesive sticker bomb sheet 16”x32” x2 $30 each AUDIO Alpine Type-S Speakers (6-3/4", 2-way, 80 watt RMS, 4 ohms) $40 BOSS Bass remote (new) $10 |
