-   -   New to RX7's need some assistance (http://www.rx7forums.com/forum/showthread.php?t=16660)
Morinkashi 12-20-2014 03:59 AM
Hi guys, i have a 1990 GTU shell im putting the car together kinda like a barn find, the car is completely disassembled and my real question is.
what kind of deletes can i do to the car not worrying about emmissions or anything like that?
I have installed a PS=less rack, A/C removed, and not installing air pump either.
I would like to have just the essentials for the engine to run nothing else.
Thanks and sorry if im out of place
driftnfb 01-02-2015 05:37 AM
Do some searching... you can do an emission delete and block off plate.. all you need are some vacuum caps and the block off plate )if i remember correctly).. Search!
After you delete what you dont need off the rotating assembly it is recommended you buy a double pulley for your alternator and run Two belts.. Search!
