-   -   Water punp issues (http://www.rx7forums.com/forum/showthread.php?t=16522)
hap2 01-24-2014 03:40 AM
Water punp issues
My car (1987 RX-7) was leaking coolant. I took it in to the local Canadian Tire to get pressure tested. The said it was the water pump. I fear those guys don't tell me the truth just so that i can spend big $ to them to get it fixed when it just might need gaskets or something a lot less serious. Anyway, in this case, I have to believe them.
Anyway, my main questions are:
Is there anyway to check that it's the water pump for sure?
Also, what is the coolant capacity for my 87 RX-7 non-turbo?
Also, where's a good place to get a water pump & also muffler / tail-pipe?
Also, what am I looking at for time to change the water pump?
Thank you very much.
black rocket 01-26-2014 10:43 AM
Coolant capacity is 9 quarts (9.2). Don't recommend cheap replacement as you will pay for it. Contact Atkins Rotary and ask for Dan , he will take care of you. Shouldn't take too long, an hour or two maybe. It is also a good time to replace t-stat at the same time. Good luck.
