-   -   TII turbo on an N/A second gen rx-7 (http://www.rx7forums.com/forum/showthread.php?t=11)
rx7pilto586 03-22-2004 10:28 PM
I was just curious is it complicated to install a TII turbo on a N/A Rx-7. I've seen a couple of peoples sites that have pulled it off and i really wanna do it but some of the stuff is a little in the gray area. for example would it be better to make the intercooler top mount or front mount? Which way would produce better performance and which would be better for easy install. If somebody could give me a list for all the parts i have to fabricate. If you could include dimensions that would be helpful. Also of some sites of this project documented would help.
thanks,
rx7pilot586
2ROTORMOTOR 03-23-2004 04:03 AM
first of let me ask you a question. Do you mean just the turbo, or the whole motor? If its the turbo only its pretty much more complicated than just installing a turboII motor.
rx7pilto586 03-23-2004 04:26 AM
just the turbo
i wanted to just put the turbo on the engine cuz its a good motor and the turbo would be cheaper than a new motor. Plus the n/a motor has higher compression so ill get more power. And finding a TII motor is gonna be hard or at least finding a good one with a good turbo. Another thin is i dont really have the equiptment for an engine swap. But if i get a parts list now i can fab. all the parts at my high schools welding shop.
2ROTORMOTOR 03-23-2004 06:24 AM
Re: just the turbo
Ok. like I said swapping the turbo is alot harder than you think. The thing is that, the way the n/a Intake manifolds are made, it doesnt allow much room for the turbo. Some people have done it and they work greak but they have to mod the fenderwells and what not. In order to make it work. you would need a turboII lower intake manifold and upper intake manifold. But its not as easy as it sounds. The turbo II is 4 ports and the 86-91 n/a are 6 ports. That means caping of the 2 extra ports and them having the ports on the intake manifold line up with the ports on the engine. But that is one way of doing it. I can show you another way.
AutoXFC3S 06-13-2004 12:48 AM
i was thing of doing the same thing and when u say block 2 ports off.... how in the world do u just block them off???
AusTexRex 06-13-2004 05:48 AM
Block them off with plates. Do it right and the added force will blow hard though the 4 remaining ports. I've also heard of people making a fitment piece that routes the 6 ports into 4 before attatching to the manifold. Don't spend your time and money putting a turbo on an N/A motor. Supercharge it if you're going to keep that motor.
The higher compression is actually a drawback, as it limits the amount of boost that can be safely added to 10 psi. You can pick up a good turbo motor for cheap, or you could buy a blown turbo + 13BT and send it off to be rebuilt by Kevin Landers for 1500. Get it ported and such for more power and it would be 1750
With the added power the N/A Tranny will crap out very quickly so that will need to be replaced as well. Personally I'd just buy a TII with a blown motor for 500 bucks and get it rebuilt.
Shaggy 06-13-2004 06:11 AM
Aus...you say it would cost $1500 - $1750 for the rebuild...is that just the labor?
2ROTORMOTOR 06-13-2004 08:01 AM
ok best thing to do is buy a jdm motor, which should run anywhere from 900-1200... then use your tranny, harness, and turbo ecu... dont start with the blocking of shit, cus its not worth it... youll spend a hell lot more time and money doing that shit.....
7Tim 07-01-2004 09:06 AM
if you really want to turbo a N/A engine, Aaron did it.
http://www.aaroncake.net/RX-7/naturbo.htm
2ROTORMOTOR 07-02-2004 03:56 AM
aaron is adick head, if he wasnt a moderator I would simply tell him off in the forums.... that motherfucker pisses me off.... he thinks he knows everything when in fact,he doesnt. the whole tb setup he has is fukin stupid and the most ignorent thing to do.... check out that "srawberry". anyways, if you want some good info, just ask in the forums....
