n/a fd engines????
Re: Enigne up-keep
so when would be a good time to change the oil every ?? miles? |
I change mine every 1.5-2k miles depending on how the oil level is, the color of the oil, how hard i've been driving it, and if there is any gasoline fumes in it. Since oil in a rotary engine is mostly part of the combustion process it isn't ran through the engine and put back into the pan like it is on a piston, so the oil stays fresh for longer. BUT, oil can clump or when ran through the turbo get junk in it, and throwing that into a rotary engine can be bad. I prefer to change it every 1.5k miles and not worry about it. I only use real oil I don't mess with synthetic, there used to be plastic sand particle in it that were terrible for rotary engines. There aren't anymore... but I still prefer the real stuff.
thanks always feels good to learn something new everyday:)
Hey Aus...how long do you wait before you change the oil if you don't go the 1.5 k miles...2 - 3 months?
really depends on how I've been driving it lately, how hard and all of that. If it's been sitting I'll change it in 3-4 weeks. If I've been driving it regularly probably 1.5 months.
ok can some1 clarify about using synthetic oil? is it good or bad for a turbo type II? if not whats a good oil weight?
